Rear Axle Seal Leaking - Ford Powerstroke Diesel Forum
Old 01-09-2012, 11:51 AM
Noticed last night my passenger side rear wheel is covered in diff fluid. Time to replace the axle seal.
Anyone having luck using a parts-house (NAPA/ "shmucks" Orielly) brand for the seal? I've heard some people complain about them leaking, but my local stealership says it will take them 10-14 days to get the seal in...I just can't wait that long.
Old 01-09-2012, 12:24 PM
I used SKF seals in mine, no issues yet.
Old 01-09-2012, 01:27 PM
It seems like all I can find locally is "National" brand. Anyone have experience with them?
Old 01-10-2012, 05:37 PM
have the same issue with my truck getting ready to put one in from parts store as well. have heard that sometimes they work sometimes they don't
Old 01-10-2012, 06:12 PM
Might need to check the vent, my driver side rear was leaking so I replaced it well it lasted about a month and started leaking again, come to find out the vent was clogged and causing the axle to pressurize and push out the seal.
Old 01-10-2012, 08:15 PM
I'll probably change the seals out anyways. I bought this truck a few months ago, and am planning on flushing the differentials. Might as well kill two birds at once.
Just curious, whats the best way the clean out the vent tube?
Old 01-11-2012, 07:03 AM
Take the vent hose off the axle and see if you can blow through it, if not it's clogged and where the vent tube goes stick a small drill bit or something through it and see if it's blocked and that is how you clean it out.
Old 01-11-2012, 09:02 AM
Alright thats what I figured.
I'll probably give it a good soak in the parts washer, then hit it with some compressed air just to make sure all that crap is out of there.
