ts chip high idle - Ford Powerstroke Diesel Forum
Old 09-09-2007, 03:22 PM
ts chip high idle
just put a ts chip in my 95 psd. one of the settings is high idle. when you put it on high idle it does fine but when you turn it off high idle the truck turns off, just dies, even if you give it throttle it still turns off when you try to let it idle. does anyone elses do this or is this not the way it is supposed to work .
Old 09-09-2007, 03:26 PM
Desert Shield/Storm Vet
Hmm doesn't sound right. I don't know for sure though.
Old 09-09-2007, 04:50 PM
I had a TS with High idle, and I never had my truck die when changing the setting. You have a problem. Try unhooking both batteries and remove the chip. Then, clean the contacts and put it all back on. Might help, who knows.
Old 09-09-2007, 05:06 PM
PIPE HITTER
yeah I would say double check to be sure everything is clean where the contacts are. I have the TS with high idle, and it deffinately does not do what your descibing.
Old 09-10-2007, 05:55 PM
today it didn't do it then . later this evening it did. i dunno it thinks on its own
