Clear Signals and HIDs
Just finished throwing these puppies on the other night. The HID kit has high and low beam with 6000K bulbs
Off: ![]() On: ![]() Night Shot: ![]() Waddya Think? Last edited by alberta 7.3; 09-09-2007 at 07:11 PM. |
Looks great!!
Have you had any trouble with the wiring harness heating up or melting with those H.I.D.s?
Sweeet!
Where did you get these from, and how "ballpark" did it run you? I imagine the night time driving vision is much improved over the stock bulbs and lens. Craig |
Wow - that looks GREAT! Good job man!
They look good, I like how they give the light housing a bluish look to them...
headlights/corners/signals were from Advanced JDM for 160ish for all 6 pieces. I still don't have them aimed exactly yet (a little low, pass side needs to go to the right a bit) but Holy S@#$ Batman!! They're not blinding anyone, and the light seems to illuminate reflective signs a couple miles away. After a few hours of highway driving, the light doesn't seem to cause fatigue like squinting through the blackness with halogens used to. The only thing that sucked is since my truck is for Canadian market, I had to do a little "re-wiring" on the DRL module, since it is not recommended to use HIDs as daytime runners (reduced voltage reduces ballast life.) In the near future, I will be installing some fogs in the outer bumper holes (hopefully my old PIAA 959's) and have them for fog and DRL duty. Last edited by alberta 7.3; 09-11-2007 at 05:41 PM. |
Wow man - those did cost a little coin, but well worth it I bet! Looks good and let us know how the fog lamps install goes!
looks great even better lookin at night. the only thing might be that driver side running light looks different than the other 4. maybe its from the flash
Good eye on the marker lights! The one on the driver's side is an experiment with an LED circuit board. |
