need help with U Joint selection - Ford Powerstroke Diesel Forum
Old 01-07-2012, 04:09 PM
Send a message via AIM to Kyle J
im gonna buy 2 u joints from auto zone just a duralast brand for the rear drive shaft , im gonna put splicer's in this spring but for $10 ill just throw in the duralasts. my question is online there are two different types
One says - Application: Rear shaft
With 3 joint shaft
and the other says - Application: Rear shaft
With 2 joint shaft
wich ones do i want for my truck its a 1997 f350 150k regular cab 4x4
U-Joint | 1997 Ford F350 1 ton P/U 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
Old 01-07-2012, 05:08 PM
anyone know whats the difference and what one i need?
Old 01-07-2012, 05:14 PM
On some trucks, there are two driveshafts. One coming from the Transmission (or Transfer Case) and one going to the differential. On those, there's a U-joint in the middle. My 94 is a one piece. Hell, I think most of them were. But check.
Old 01-07-2012, 05:26 PM
Send a message via AIM to baderic03
Kyle if your truck is a single cab 8ft bed it takes two joints
Old 01-07-2012, 05:27 PM
Kyle were on the cape u located? I'm from the south shore
Old 01-07-2012, 05:28 PM
Mine is reg cab 8ft bed. Single shaft... Now maybe only the 4x4's are single. Never messed with a 2wd.
Old 01-07-2012, 06:58 PM
Well, do you have a 2 or 3 joint shaft? 2 u joints is for a single piece shaft. 3 is for a two.
Old 01-08-2012, 01:38 PM
there a u joint at the rear nere the axle and then it has a joint before it goes into the transfer case? that is a 2 peice right? i dident know they even made a 3 peice drive shaft.
Old 01-08-2012, 01:39 PM
and Eric im from sandwich right over the bridge
Old 01-08-2012, 03:04 PM
you need the one for 2 the drive shafts with 3 are from extended cab and crew cab modles
