Boost and MAP - Ford Powerstroke Diesel Forum
Old 01-07-2012, 03:42 PM
Boost and MAP
I was reading an tech write up on installing a boost T in the MAP line, is this an accurate way to do it?
The other thought was punch a hole in the intake Y pipe
Old 01-07-2012, 03:53 PM
Looks right. I tapped the spider but that's just me.
Old 01-07-2012, 03:56 PM
Is this for reading boost pressures?
Old 01-07-2012, 04:28 PM
thats where i did mine, but i used big copper peices from the home depot plumbing section lol, but i used clamps as well just to make sure it dont try to blow off
Old 01-07-2012, 04:35 PM
Yes it sure is.
MAP line tap is quicker, but some have a little fluttering in the reading for whatever reason.
Old 01-07-2012, 05:44 PM
i have a flutter only in the high end like 30-35 lbs, but anything under is still fine, gonna relocate eventually tho
Old 01-07-2012, 09:47 PM
To where? I was leaning towards the inline cus its easy, but if it's more accurate to do the pipe then I'll just do that.
Old 01-07-2012, 09:50 PM
its less bouncy on the needle with it on the y, but the map line is to easy, i have it that way now, but for stock its just fine
