Rear Driveshaft - Ford Powerstroke Diesel Forum
Old 01-06-2012, 06:17 AM
Rear Driveshaft
I have had a leak where the rear driveshaft mates to the transfer case. It is throwing oil all over my muffler and the underside of the truck. The leak leaves a small puddle overnight under the truck on the ground. I had my mechanic replace the seal between the transfer case and the driveshaft but it is still leaking. We are now thinking we need to replace the U joint and the Yoke. Any ideas on where I might be able to order these?
Old 01-06-2012, 08:21 AM
well if he just replaced the seal it will leak if he didnt ajust the spring in the seal. i am sure the yoke is warn too. if it was caused by dirt, dust or sand, it will dig into the yoke and even a new seal wont seal right. if it was my truck i would have replaced both at the same time.
Old 01-06-2012, 11:05 AM
Send a message via AIM to baderic03
Order it from ford or maybe Randy's ring and pion
Old 01-06-2012, 11:35 AM
Tried the Ford dealership I work at, no luck. Ford doesn't make them anymore. I will have to check out your other suggestion though. Thanks.
Old 01-06-2012, 11:52 AM
If no luck let me know and I'll call my bearing/driveshaft guy and get one for u
Old 01-06-2012, 01:19 PM
I have a local shop here I am going to try next week after I pull the old driveshaft. If they cannot help I will let you know. Thanks for the help.
