are these stock or aftermarket caster/camber bushings? - Ford Powerstroke Diesel Forum
Old 01-02-2012, 12:34 PM
Do these look like stock or aftermarket caster/camber adjustment bushings??
Old 01-02-2012, 01:40 PM
My '95 has the identical setup, so I'd wager you're looking at the OE adjuster.
Old 01-02-2012, 04:52 PM
The aftedmarket ones look pretty much the same so i wasn't sure.
Old 01-02-2012, 05:11 PM
I know these are the OEM ones....
HTH.
Old 01-03-2012, 04:54 PM
My truck has a lift on it from the previous owner, not sure how much of a lift. I dont think they put the adjustable ones in there when they did the lft. The tops of my front tires lean inward something awful and the inner part of my tires are bald. Im hoping some adjustable ones will fix this problem.
