Chip or Valve body? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-30-2011, 06:37 AM Thread Starter
truckyard1's Avatar
Quoted: 18 Post(s)
Chip or Valve body?
Kinda having a dilemma: I'm eventually getting both a 6pos chip, and the BTS valve body for my trans. From what I've heard, the chips are supposed to fix some of the shifting issues, but would the valve body need to be figured into a custom burn? Or is it the other way round
Rob
'95 F350 CCLB, "Project Moneypit", ZF5, 4x4, straight piped, DIY E-fuel, more coming
'63 Jeep Truck, Chevy motor, Ford 9"
truckyard1 is offline
post #2 of 10 Old 12-30-2011, 06:50 AM
baderic03's Avatar
Send a message via AIM to baderic03
Depends who does ur tuning and ur Trans but your best bet is to do both just don't get generic tunes
As my Trans guy put it if there ain't anything wrong w ur valve body mod yours bc u don't know if the reman one has a hidden problem
97 f350single cab auto
4:10 axles spooled front axle
3in down pipe to stack
Intake 6637
140v idm mod
Efuel all built In house
II s475 .90 turbine spool....
Irate T4 304ss up pipes
T500 with gen3 pump
450/400s hush power
Comp built Trans 2100 stall converter
Gearhead tunes
531/1080 on 250/200s
baderic03 is offline
post #3 of 10 Old 12-30-2011, 07:00 AM
Quoted: 85 Post(s)
Feedback Score: 4 reviews
From what I gather the valve body will have more to do with shift firmness and the chip will have more to do with shift timing. That is something I am kind of dealing with now, just installed a custom built transmission and the shifts are not firm enough for me so the trans shop is going to rework the valve body then this spring I plan to install stage I's and go a different route than my superchip.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 10 Old 12-30-2011, 07:31 AM Thread Starter
truckyard1's Avatar
Quoted: 18 Post(s)
Well the BTS I've heard is pretty good, and for 250 bones its a pretty cheap trans upgrade. What did you mean by "remanned"? Also I'm planning on getting the Tony Wildman chip, its a little more expensive but I like the tunes he offers.
Rob
post #5 of 10 Old 12-30-2011, 07:53 AM
baderic03's Avatar
They take core valve body's and mod them so it could have a problem and u wouldn't know or it slipped through there quality control
Intake 6637
140v idm mod
T500 with gen3 pump
450/400s hush power
Gearhead tunes
post #6 of 10 Old 12-30-2011, 11:40 AM
backwoodsboy's Avatar
I'd say valve body then tunes.
It would be a shame to get the truck tuned, then fry the transmission because the valve body wasn't up to the task.
backwoodsboy is offline
post #7 of 10 Old 12-30-2011, 12:13 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
get the VB and then tunes.... but tell BTS that you are plannig to put a chip in the truck so he can modd the VB accorgingly thats what he did for me.
as for the hidden problem with cores... i belive all his VBs are top notch when you get them, and could elimintate that problem by sending in your first you can avoid that problem but ure turck wil be down longer.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #8 of 10 Old 12-30-2011, 02:10 PM Thread Starter
truckyard1's Avatar
Quoted: 18 Post(s)
That's the feedback I've been hearing about his work, so I wasn't real worried. The thought was grab the VB out of my down trans so I can avoid any downtime Is there anyway to tell if a VB is good/bad?
Rob
post #9 of 10 Old 12-30-2011, 02:43 PM
ol_Blue97's Avatar
thats exactly whay i did..... i really dont hink it matters becaue he compleetley rebuilds them
have you tried John Wood yet... im intersted to see how his VB is?? not to be a guenypig or anything
FRANK THE TANK
post #10 of 10 Old 12-30-2011, 05:04 PM Thread Starter
truckyard1's Avatar
Quoted: 18 Post(s)
Haha no I haven't. I'll let someone with deeper pockets find out for me tried and reviewed sounds better to me
Rob
