A letter from FORD
I just recieved in the mail today a recall notice on my 1996 F350 CCLB 4X4.
Its stats that my truck has not yet had the " speed control system modification " Anybody know anything about that? Thanks, Phil |
Wth is that?
They change out the brake light switch. As I understand it , the switch controls the brake lights and the cruse control.
It does, so does that mean the cruise won't cut off when a light is out or when I tap the brakes now?
Mine seems to be working just fine, is some thing that I should have done?
It's probably the recall on that switch on the front of the master cylinder, the secondary one that interrupts the cruise.
Cruise control is _supposed_ to cut off when you tap the brake pedal. And no, this has no effect on how the cruise cuts out when a bulb is burned out and you hit the turn signal. That's inherent in how the truck is wired. |
There was JUST a thread about this and I posted a pic showing the little fuse in a wiring harness that they add. Go do it now.
I did one on my f150 a few years back like that, supposed to stop the catching fire randomly thing
