running a stack through the hood of my 96 250??? - Ford Powerstroke Diesel Forum
Old 09-07-2007, 05:22 PM
Send a message via AIM to Wboy247
i was told that every bend in the exhaust takes off about 5 horses if i ran two 90 elbows one from the turbo over the right valve cover then turned straight 90 up((Something like that, maybe alittle more modification)) through the hood with a chrome stack mounted to the hood would that work?? seeing how the pipes so short though would my egts be higher? i like to do it just for the track i think only 6 inches out of the hood is legal here in Virginia.
Old 09-07-2007, 05:32 PM
The Fat Mod
It will probably run a little cooler. Not sure about the loose 5 horses at every bend. Someone else maybe able to answer that question. Never heard that though.
Old 09-07-2007, 05:35 PM
Desert Shield/Storm Vet
Yeah if anything your going to free up pony's by doing away with the restrictive downpipe on your rig.
Old 09-07-2007, 05:59 PM
i mean even if i put a regular exhaust on it would running it through the hood be better for me im not settin it up to pull. but the egts is what would concern me.
Old 09-08-2007, 09:29 AM
Turbos spool better with a "long downpipe" that idea you have, will be something like one, but If I wer you I would probably use an aftermarket downpipe, about 4" an then use a straight pipe...
5HP por each bent is kind of optimistic, it also dependes on the type of the bents, is not the same a mandrel bent and the factory creepy bents...
Old 09-10-2007, 04:31 PM
i c i c thanks for the info
Old 09-10-2007, 07:29 PM
What ever you decide, you better post pic's. I want to see that hood stack!
Old 09-11-2007, 07:50 AM
will do will do. What do yall think about the stack black powdercoat or chrome? the truck is white and everything else is black except the bumper and door handles. the wheels i want to get are gonna be white.
Old 09-11-2007, 11:12 AM
Blck if you would think on black wheels... otherwise chrome...
Old 09-11-2007, 02:25 PM
I think black would look pretty cool!
