new guy with some questions - Ford Powerstroke Diesel Forum
Old 12-23-2011, 03:22 PM
i recntly baught a 95 f250 psd with a 5 speed tranny and am doing some rutine mantainance to it and i found my gpr and my old one is completely different from the one i got from the parts store. my old on looks like the one in the pic on the link http://www.powerstroke.org/forum/94-...-location.html and am unsure if the po put a different kind on it or what to do. and i ordered a boost and egt gauge from glowshift where are the ideal locations under the hood to place the sensors
Old 12-23-2011, 03:31 PM
Full A-Team Member
They used a western snow plow relay. Best bet for relay....
586-902 Stancor General Purpose / Industrial Relays
And for the boost gauge, there is a line running from the passenger side intake to the map sensor, 'T' into that for boost
Old 12-23-2011, 03:34 PM
Full A-Team Member
Let me add....for IDEAL locations....
Tap into the intake 'Y' for the boost guage (remove from truck first)
And for the EGT probe, the flat part on the bottom of the driver exhaust manifold
Old 12-24-2011, 12:58 PM
Make sure your parts store gave you a glow plug relay, rather than a glow plug module.
As for guage probe locations, do what fordman said. Whatever you do, DON'T put the EGT probe after the turbo, and then add 200 degrees to what your guage is reading. Simple thermodynamics proves this is half-assed at best.
Old 12-24-2011, 01:05 PM
they gave me a relay its a cylinder with 2 bigger posts and 2 smaller posts with wires already on them with a connector. do you need to pull the exhaust manifold to install the prob for the egt or can it be drilled out while its on the truck.
Old 12-25-2011, 12:28 AM
Sounds like a GPR to me, so you're good to go there.
It isn't necessary to remove exhaust manifold to drill for a egt probe. Make sure you have the truck running while you drill. This allows the shavings to be blown out, and prevents you from dusting the turbo with them.
Old 12-25-2011, 07:46 AM
one more question for you guys how hard is it to remove the fuel filter assembaly from the intake valley it looks like the po might have had a visitor make a nest under it and i want to get it all cleaned out.
Old 12-25-2011, 03:22 PM
Full A-Team Member
Its really easy, only 2 bolts hold it on and there are a few fuel lines (make sure you get new line for re-assembly) here is a how-to thread.......
17* HPOP install in an OBS by Matt P
It is for HPOP replacement but tells how to remove the bowl
Old 12-27-2011, 04:15 AM
here is what i found under the fuel filter
Old 12-27-2011, 04:16 AM
