fuel gauge - Ford Powerstroke Diesel Forum
Old 12-20-2011, 03:00 PM
fuel gauge
on my 95 f350 cclb once it gets around 1/2 a tank the gauge starts to sway alot when i take left hand turns. People have told me that the 1/4 tank mark is the E line basically. but it should be a 15 gallon tank and if i fill up right when the gauge reads a lil over 1/4 tank it takes a little under 12 gallons and it goes way past the full line. Do your guys do this and am i safe to run past the 1/4 mark?
Old 12-20-2011, 04:28 PM
I can go til "e" on my 96 f250. I've had my front tank dropped, the sensor is right in the middle. I noticed when I come to a stop my fuel gauge drops, but really it's just the fuel sloshing forward away from the fuel level sensor.
Old 12-20-2011, 05:50 PM
this is my rear tank
Old 12-21-2011, 03:51 PM
my front tank will run till E. the rear runs out at 1/4.
Old 12-22-2011, 07:19 AM
every gauge is different. they're 18 & 19 gallon tanks but i've gotten 22 in my front after running it dry. do both tanks work? Run one down till you hear is lose fuel then quick change to the other tank. You'll know where on the gauge it runs out. My front goes below e and my rear runs out still reading 1/4
Old 12-22-2011, 07:47 AM
my front tank does not work. Thats another problem that im experiencing. Ive changed to switch and it still wont work.
Old 12-22-2011, 10:19 AM
both mine go down to e, ive realized that my back tanks seems to drop faster then the front but like mentioned before every gauge is differnt
Old 12-22-2011, 06:57 PM
Ya both of my tanks go all the way down to the e but I've never gone much past that.
Old 12-23-2011, 07:35 AM
Is the sending unit not working or is the selector valve not working?
Old 12-23-2011, 05:35 PM
I can take both of mine down to e, but the rear tank never goes all the way up to F even when i filler up all the way up the neck.
