97 f350 psd automatic help - Ford Powerstroke Diesel Forum
Old 12-17-2011, 02:38 PM
When taking of from a stop sometimes it wont rev up past 1500 rpms or so then finally it will get enough rpms to spin the turbo. When it does this it sounds as though it is missing. If you are on a incline or starting a load it does it worse. It seems to help if you really ease into the throttle and build up the rpms slow. Could it be injectors or what. Any help i could get would be greatly appreciated. Also my fuel mileage has gotten worse
Old 12-17-2011, 03:53 PM
Send a message via AIM to baderic03
Check your fuel filter and pressure. Check for codes check your oil level
Old 12-17-2011, 04:46 PM
Regular maintenance first. Need to check fuel pressure and for boost/up pipe exhaust leaks.
Old 12-17-2011, 04:49 PM
The Tamed Racing Driver
CPS? .
Old 12-17-2011, 06:41 PM
thanks for the info, new fuel filter and the oil is good
Old 12-18-2011, 06:34 PM
Cps fuel pressure. Under valve cover wiring harness loose? Any miss at idle?
Old 12-19-2011, 02:19 AM
if you hold your hand to the exhaust it has a little flutter
Old 01-05-2012, 09:15 PM
...kind of looks homeless
It sounds like he's reading rpm's which would rule out the CPS, right?
Old 01-06-2012, 04:27 AM
It's running, it's not CPS right now.
What about all the other things we've asked? Checked them?
Old 01-06-2012, 05:25 PM
Am going to take valve covers off next week and look for a short. It had a new cps put on as a recall year or so back. hopefully I will find something. I have put on a new fuel pump a while back as well
