HELP... zf5 swap ?
I am about to buy a donor truck if the parts will fit. donor is a 91 f250 diesel with zf5, my truck is a 96 diesel with e4od. will all the parts work on mine? flywheel, clutch, tranny, crossmember, clutch pedal?
anyone know? I heard 92-97 is what to look for on the clutch pedal but im not sure on everything else. thanks |
AFAIK everything works, but hopefully someone can chime in on pedal tho
If you're going to all that trouble, you're putting in a new clutch, right? And what kind of flywheel does the donor have? If it's a dual-mass, like the OBS OEM, you'd def. want to replace that with a single-mass as well.
Are both trucks 2WD (or both 4x4)? Edit -- I _just_ read on another forum that the flywheel bolt pattern on the IDI is totally different, so you're probably looking at a new flywheel and clutch in any event. Last edited by madpogue; 12-16-2011 at 12:20 PM. |
Both 4wd, i will be putting a single mass in it. I believe the tranny will bolt up but its the weaker 42 instead of the 47 zf5. Thats what i have read anyway. But i cant find any info on the clutch pedal or crossmember yet.
The pedal is 92 and up specific. But one from a 150 with a straight 6 will work. They are all the same regardless of motor. The crossmemeber is the same but backwards I believe
