stalling? - Ford Powerstroke Diesel Forum
Old 12-15-2011, 04:20 PM
stalling?
my 95 f350 sometimes kills while idling. and sometimes while driving it seems to misfire? any suggestions to the problem?
Old 12-15-2011, 04:35 PM
CPS can cause it to just die instantly. Does it idle rough?
Old 12-15-2011, 04:51 PM
Could be many, many things.
CPS would be first.
Could be a bad UVCH.
Dirty fuel, filter, fuel pickup tube.
Dirty oil.
Bad ICP sensor.
Old 12-15-2011, 06:30 PM
by cps do you mean camshaft position sensor? it does idle rough sometimes.i just serviced it, new oil oil filter fuel and air filter. whats a uvch?
Old 12-15-2011, 06:34 PM
Yep, camshaft pos sensor. UVCH is the under valve cover harness. Do some searches, you'll find out. They can get burned up, chaffed, etc. And since they provide the power to fire your injectors, it can cause rough idling and dying.
Old 12-15-2011, 07:03 PM
i'll try unplugging the icp and running it and seeing what it does
Old 12-16-2011, 04:28 AM
haven't been underneath the valve covers lately?
Old 12-16-2011, 04:32 AM
They can still chaff and the pins can get burnt up or get loose without ever touching them.
Old 12-16-2011, 06:44 AM
Full A-Team Member
If there is oil in the plug of the ICP it is shot
Old 12-16-2011, 01:15 PM
yeah its got some oil in it. i unplugged it this morning and went to work and it ran fine.on the way back from work when i would stop at a stop sign or light and had my foot on the brake it would idle kinda rough or kinda high. so i pulled over and plugged it back up and cranked it and it ran for about a minute then stalled, so i unplugged it again and it ran fine. safe to assume that this is my problem?
