OIl Pan Replacement - Ford Powerstroke Diesel Forum
Old 12-15-2011, 03:08 AM
OIl Pan Replacement
Hi,
I have a 97 F250. I have the trans, down pipe and flywheel out. Can the oil pan be replaced with out removing the motor. I have received mixed responses. Has anyone been there-done that?
Thanks
Old 12-15-2011, 04:16 AM
Not done really good. Need to pull it to flip it upside down and let the RTV sealant set really really good.
Old 12-17-2011, 06:10 AM
There may be one or two people who claim they wrestled a paper seal in without removing the motor but the results are not good. To do it right you need to pull the engine and put it upside down on a stand. My oil pan seal leaks at the front but it's not enough to warrant pulling my motor. Good luck!
Old 12-17-2011, 10:23 AM
Interior Guru
Feedback Score: 3 reviews
Well said.
The motor needs to come out because of the oil pickup tube, and front cover.
Old 12-17-2011, 01:19 PM
I have seen guys use some heavy duty epoxy to hold a fiberglass shell over the bottom of the pan to repair the rusted areas. It seems to be pretty permanent.
