Non ebp pedestal? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-14-2011, 09:13 AM Thread Starter
F350oldskool's Avatar
Non ebp pedestal?
Ive been thinkin about buying this new different pedestal bit i dont know or cant kind what benefits it will have. or the cons it could have also. its cold where i am and i know that valve is to aid in warmup but sometimes its closed to the point that i have that hiss noise all the way to work. (20 min drive) and my fuel mileage has gotten worse. is it best to buy the different pedestal or should i rebuild that valve?
F350oldskool is offline
post #2 of 14 Old 12-14-2011, 10:01 AM
atvrider93's Avatar
Quoted: 8 Post(s)
cheapest way to do it is just make sure the valve is open and unplug it. or you could put it on a switch so you can control when its on. How cold is it there? do you plug the truck in at night?
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 14 Old 12-14-2011, 10:10 AM
Mine does the same thing and i cant stand it. Makes it worse with the large pipes. Sounds horrible
resortepiloto is offline
post #4 of 14 Old 12-14-2011, 10:16 AM Thread Starter
ok perfect . i found a place by me in greeley CO that has one for 152. not to bad i think. it has gotten to -15 at night before. yes i plug it in every night.
post #5 of 14 Old 12-14-2011, 10:28 AM
Full A-Team Member
Fordman247365's Avatar
Dont need any of it, took mine out last spring and installed a blank pedistal, it doesnt warm up any different with or without it.
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #6 of 14 Old 12-14-2011, 10:37 AM
atvrider93's Avatar
Quoted: 8 Post(s)
your options for removing the EBPV are the blank pedestal or removing the valve and plugging the hole. its probly 1-2 hours of work max to get the old valve out and plug the hole
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #7 of 14 Old 12-14-2011, 10:39 AM
Full A-Team Member
Yup either do that or get a blank one, costs more but is mistake free, and while you are at it gut the butterfly and shaft out also, will drop your EGT's buy 50-75*
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #8 of 14 Old 12-14-2011, 06:18 PM Thread Starter
will there be any other benefits other than lower egts? quicker response or anything?
2001 F250 SD ZF6
4in MBRP straight
DIY intake
TS 6 pos chip
HPX
FRX
CCV mod
Boost fooler
Wicked wheel
She aint the fastest but she runs good
Jeremy- Ft. Collins, CO
[URL=http://s1251.photobucket.com/user/F350oldskool/media/image.jpg.html]
post #9 of 14 Old 12-14-2011, 06:22 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Replacement O-rings for Ford Diesel Engines
That's what Bob has it for.
Acutally, you were probably looking at his. He's good.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 14 Old 12-14-2011, 07:13 PM
Full A-Team Member
Not every mod out there is for a perfomance gain. This will prevent the almighty oil leak from under the turbo from happening.
My whistle is more defined...
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
