i need advice asap - Ford Powerstroke Diesel Forum
Old 12-13-2011, 07:25 PM
i need advice asap
alright i just got my first diesel its a 95 regular cab long bed 4x4 with a lift well its got alot of torque and i snapped the rear ujoint got it fixed and was backing outta the shop when the drive shaft popped outta the tranny how would it just pop outt?
Old 12-13-2011, 07:49 PM
welcome to the org, i would go out and look at how the driveshaft connects but its dark outside. i know someone else on here will know for sure
Old 12-13-2011, 09:40 PM
Welcome to the org, and I know this sounds dumb but was your axle straight when you put it back in, like at the knuckle? If its a 2 piece that is. Or mabye your axle is wrapped up
Old 12-14-2011, 04:01 AM
Send a message via AIM to baderic03
He has a one piece shaft with a flange on the Tcase How much lift is on the truck and put a dial on the axle and check piņon angle make shore it's not to steep
Old 12-14-2011, 06:28 AM
If your getting lots of axle wrap with the lift it will pop out. I would check out the quality of the lift and have someone watch the rear springs and see how bad they are twisting up
Old 12-16-2011, 08:26 AM
what should the pinion angle be? and its got three blocks on the rear so im pretty sure they are allowint it to move just enough to where it can pop out
Old 12-16-2011, 11:39 AM
Three blocks on the rear? I've always heard that stacking blocks was a no-no. Cheers!
Old 12-16-2011, 11:42 AM
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
how much lift do you have?? could be to much lift not enough drive shaft
Old 12-19-2011, 07:53 PM
its a six inch i think i just gotta lengthen my driveshaft
Old 12-19-2011, 07:57 PM
Shade tree mechanic
Three stacked blocks
