Fuel Heater - Ford Powerstroke Diesel Forum
Old 12-11-2011, 01:44 PM
Fuel Heater
does anyone have any advise on how to get the fuel heater out? and is it really worth messing with? i live in ohio and its getting pretty cold out now (teens and 20's) does it really help that much? thanks
Old 12-11-2011, 02:30 PM
I think its a 17 or 18mm I used a crows foot wrench
Old 12-11-2011, 04:32 PM
I'm new at this and haven't done t myself, but I believe I've read that the black plastic center standpipe is reverse threaded so it doesn't want to unthread itself if the fuel filter was to be really stuck while removing the fuel bowl cover.
I suspect it shouldn't be very tight at all (it's plastic) and you should be able to feel that you are loosening it or not.
Let us know how it works!!
Old 12-11-2011, 04:40 PM
Remove it.
Old 12-11-2011, 04:42 PM
But seriously, it's just reverse threaded, and there is a little spade fitting where it connects to the circuit. Just take it out, put the standpipe back in, put the filter back in and off you go.
Old 12-11-2011, 06:55 PM
Standpipe is LEFTHAND threaded as mentioned. 7/8" crows-foot wrench to remove it. Cheers!
