injectors?
stage 1s or 2s what to get? any input would be great. thanks
Who will you be going with is the question, if you want them you should do the support mods to keep them happy so nothing breaks when you are doing them, but get an hpop and stage 2's with valve springs and what not.
2's at the minimum. I've heard countless people say that they wish they went stage 2 instead of 1. Stage 1 is only 20cc above a stock SD.
Go with the largest you can afford, you can always have have them detuned.
Lmao, could also go hybrids that would be sweet lol
Are stage 2's feasible with a stock-strength single mass flywheel clutch? If I can get away doing 2's with an HPOP and tunes, I'll be one happy fella.
Stage 2 injectors will require an aftermarket a stage 2 hpop, as well as after market fuel pump like an air dog or fass, as well as custom tunes, intake, exhaust.
If you are needing injectors because you have a couple that are bad. You can replace the bad ones with stock remans for about 150 dollars. Then you can save your money and upgrade as you can. |
Well with stage 1's 08spartan needed a clutch by weeks end.
But how does he drive? Stage 1's are not much more power...Ike stated its only 20 cc's bigger... But if he drives it like he stole it, I'm sure the clutch was on its way out... And he's a Texas boy so I'm sure he is a race car driver :p
I think you should have a goal frist. Then see what it takes to get you there.
