Carrier bearing support - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-07-2011, 07:00 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
Hey guys i need to do the carrier bearing support on my truck and im wondering if anyone knows what size it is.
I checked the local parts store and they've got a few different sizes. Im also doing u-joints front and rear. I assume they are the same size?
By the way its an ext. cab 4wd auto trans if that helps
Sent from my iPhone
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #2 of 8 Old 12-07-2011, 11:01 PM
truckyard1's Avatar
Quoted: 18 Post(s)
You have to take apart the center driveline section anyway, might as well take it apart and bring it to your local parts house. The bearing needs to be pressed on, my local Napa will remove and press on the new 1 for $20+parts. Hope that helps.
Rob
'95 F350 CCLB, "Project Moneypit", ZF5, 4x4, straight piped, DIY E-fuel, more coming
'63 Jeep Truck, Chevy motor, Ford 9"
truckyard1 is offline
post #3 of 8 Old 12-08-2011, 03:33 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
I would do that but i have no way to get to the parts store. Couldnt i just use a socket and a hammer
Sent from my iPhone
tony
1997 F250 4.10's
south bend clutch
post #4 of 8 Old 12-08-2011, 03:51 PM
dcaddy's Avatar
If you have a F 250 the size is going to depend on your GVWR. You can find this on the sticker inside your door jamb. I have what Ford calls HD witch is 8800 GVWR and my truck took the biggest that they had for that application. It is held on by two bolts and nuts. unbolt it and bolt the new one on. Hope this helps man.
dcaddy is offline
post #5 of 8 Old 12-08-2011, 04:48 PM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
Yea mines over 8500 gvwr
Sent from my iPhone
tony
1997 F250 4.10's
south bend clutch
post #6 of 8 Old 12-08-2011, 04:50 PM
jesilvas's Avatar
Quoted: 2 Post(s)
A BIG HAMMER. It was too much of a pain to do it myself. I took to a shop, 10 mins later, I'm going home to put it back on
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 8 Old 12-09-2011, 06:19 AM
Full A-Team Member
Fordman247365's Avatar
Getting the old bearing off sucks, putting the new one on is a breeze. this is going to sound nuts but I did it lol. I put the bearing piece of my drive shaft in the freezer and gently warmed the bearing, I mean warm not hot, with a propane torch. then stand the shaft up and drop the warm bearing into place....drops right on
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #8 of 8 Old 12-09-2011, 10:46 AM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
Thats a great idea especially since its cold here right now. Any one know what size it is. The options are 1.37 and 1.57 inches
Sent from my iPhone
tony
1997 F250 4.10's
south bend clutch
