valve cover gasket connectors
1K views 2 replies 2 participants last post by  deezelfromRofo
#1 ·
Looking for a breakdown of each connector. Which wire color goes to each injector, pin location per cylinder. A diagram would be great. Want to recheck pigtail wiring on valve cover gasket connectors. Thx in advance.
#2 ·
From the 1997 EVTM:
For the passenger side front connector, the wiring in the plug is:
From back to front:
A) Brown (Glowplug #1)
B) Teal (Injector #1)
C) Orange (Injector common)
D) Brown with Yellow trace (Injector #3)
E) Brown (Glowplug #3)
For the passenger side rear connector, the wiring in the plug is:
From back to front:
A) Brown (Glowplug #7)
B) Teal with Red trace (Injector #7)
D) Teal with Black trace (Injector #5)
E) Brown (Glowplug #5)
For the driver's side front connector, the wiring in the plug is:
From back to front:
A) Brown (Glowplug #4)
B) Brown with Light Blue trace (Injector #4)
C) Pink with Yellow trace (Injector common)
D) White (Injector #2)
E) Brown (Glowplug #2)
For the driver's side rear connector, the wiring in the plug is:
From back to front:
A) Brown (Glowplug #8)
B) Light Blue (Injector #8)
D) Light Green with Orange trace (Injector #6)
E) Brown (Glowplug #6)
Cheers!
#3 ·
Thank you Sir. I really appreciate it.
