Fuel line replacement help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-06-2011, 02:18 PM Thread Starter
I've noticed the 2 silver fuel lines on drivers side behind shock tower are leaking some how. Just bought new ones today and was wondering if anyone has done this before and could offer some tips on how to go about this. Thanks Bill
ford1997 is offline
post #2 of 7 Old 12-06-2011, 03:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Welcome to the org, and hope we can help, I've never replaced a fuel line before tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 12-06-2011, 05:30 PM
Chop's Avatar
I would suggest taking a good look at the oil cooler first for any kinda of leak,those lines had me thinking the same thing , after cleaning this area many times it was obvious the cooler was the culprit .
The cooler has 4 o rings that are prone to leak after so many miles and cold weather service
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #4 of 7 Old 12-06-2011, 05:38 PM
Full A-Team Member
Fordman247365's Avatar
I assume its leaking fuel not oil
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #5 of 7 Old 12-07-2011, 07:51 AM
Cratos's Avatar
the o-ring in the line could be bad, you'll need the line tool to get it apart most parts houses sell them.
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
post #6 of 7 Old 12-07-2011, 09:03 AM Thread Starter
Yes its leaking fuel just enough to make things look wet
ford1997 is offline
post #7 of 7 Old 12-09-2011, 12:53 PM Thread Starter
So is there 4 orings on these lines? Because when I bought them I thought the part guy said there werent any..... This is on a 1997 F350 powerstroke
ford1997 is offline
