7.3 Power Stroke No Start - Ford Powerstroke Diesel Forum
Old 09-04-2007, 01:35 PM
This is my first post so be gentle! Not sure i'm posting in the right section.Ok...i bought a 1997 Ford Super duty Twin Line Tow truck 4 Months ago (122,000 Miles 5 speed) yesterday it shut off on my driver,The fuel was low...but not totaly in the red.he filled it up..still wouldnt start ...But it started right up on Brake clean.The Tach works when i turn the engine over,Fuse 22 is good and has power to one side.I dont have any pressure readings to give you as of yet...(buying the tester tomorrow) Fuel is going to the Bowl...and i replace the filter & bled it...Still no start. battery is at 12.6 and i have a charger on it that brings it to 15.8...Any input would be greatly appreciated..Sonny
Old 09-04-2007, 01:38 PM
Strokin' In Dixie-Land
Welcome!
Probably the Cam Position Sensor (Under the harmonic balance area). 7.3's tend to go through them on a normal basis.
Here's a link to replace it.
7.3 Cam sensor replacement procedure
Old 09-04-2007, 01:47 PM
yep I second checking that first
Old 09-04-2007, 01:53 PM
WOW!...thanks for the fast reply's Fella's...yeah Tyson Ford Cps My cost $155.08...overnighted from a guy on ebay...$54.
Old 09-04-2007, 02:04 PM
Here's a link to cheaper ones. I think somebody on here will be able to furnish a link for even cheaper ones than this.
Good idea to keep a spare and the tools to change it in the truck also.
Improved Blue CPS for 7.3L Ford Powerstroke Diesel
Old 09-04-2007, 04:29 PM
BIG TRUCK, SMALL DRIVER
Check the oil level in the HPOP resavoir. Ford has a new part # for a CPS that is way cheaper. Not sure what it is, though.
Old 09-05-2007, 10:13 PM
Feedback Score: 3 reviews
Its not the CPS if it will start on brake clean, and the tach is moving when your crankin it.
Check the number 9 fuse under the dash and make sure its not blown, if its ok, check your ICP sensor.
Old 09-07-2007, 07:35 AM
Ok, It was the Cam sensor...put in a new one i got on Ebay and Fired right up...thanks for all the Help.I'll post some questions soon about what tweaks i can do to this truck,,,Sonny
Old 09-07-2007, 07:43 AM
Glad you got it going!
Old 09-07-2007, 11:20 AM
Wow, suprised on that, didn't figure it if the tach was movin, glad its going!
