cheap ways to in prove my 7.3L - Ford Powerstroke Diesel Forum
post #1 of 29 Old 11-12-2011, 08:04 PM Thread Starter
I'm looking for cheap ways to help my 7.3L get more air and get better air flow going to the right and left bank and any other ideas would be good and the only thing i have for my exhaust is a muffler and working on making it straight from 3.5 to 4 and then the last 4 foot will be y'ed out to 2 5 in straight pipes and they will be angled they both well come out at the tail lights
Strken is offline
post #2 of 29 Old 11-12-2011, 10:14 PM
444 ci's Avatar
cold air intake will get it breathing better sounds like you got the exhaust taken care of.
444 ci is offline
post #3 of 29 Old 11-12-2011, 10:17 PM
helsel_182's Avatar
Send a message via AIM to helsel_182 Send a message via Skype™ to helsel_182
diy intake is cheap and works great.... the stock intake is very restricting on 7.3's
helsel_182 is offline
post #4 of 29 Old 11-12-2011, 10:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
DIY intake, 3" down pipe
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 29 Old 11-12-2011, 10:56 PM
helsel_182's Avatar
also fuel bowl delete and make sure you have a grey crank sensor
wont help with air but good supporting mods
post #6 of 29 Old 11-12-2011, 10:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
How do you delete that and what do you replace it with.
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 29 Old 11-12-2011, 11:06 PM
helsel_182's Avatar
i used to have an 01 7.3 and read somewhere there is a spring or something in the fuel bowl that can be removed to increase fuel flow.... i have never done it just read about it
post #8 of 29 Old 11-12-2011, 11:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I would like to get rid of the whole thing honestly, clean it up a bit, but my filter is there on the obs.
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 29 Old 11-13-2011, 04:53 AM
you don't remove anything...you take the spring out...drop in a BB and replace spring...adds pressure to the spring which brings up fuel pressure... its called the FPR mod...hth
mojoman is offline
post #10 of 29 Old 11-13-2011, 06:43 AM
Full A-Team Member
Fordman247365's Avatar
Depending on the year of yout truck, a modded IDM and the mentioned intake, DP, and exhaust. These will wake up a stock powerstroke like having a new ride, and all are cheap.
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
