2003 motor in a 93?? - Ford Powerstroke Diesel Forum
Old 08-31-2007, 05:01 PM
Send a message via MSN to 04mach1
hey guys i have a buddy with a 03 f250 and it has the 7.3 in it..
hes swapping that motor out for a built twin turbo setup and i was wondering if that motor will bolt to my trans in my 1993 7.3 IDI truck?
what else would be needed to make this sucker run ( wiring wise )
thanks
Old 08-31-2007, 05:12 PM
pull everything!!!
you'll need to fab up a way to slip in the intercooler and computer (93's don't have either one of those)
glow plugs wiring is different
pull the tranny out of the 03 and put into the 93. (the 6.4 has a different tranny anyway)
Old 08-31-2007, 05:13 PM
i need to keep my trans...
not to mention he is keeping his..
PLUS ITS A 7.3 so it will bolt to my trans right?
Old 08-31-2007, 05:34 PM
yes, you're tranny will bolt to his motor. however, his tranny probably won't bolt to any other engine without an adapter.
Old 08-31-2007, 05:35 PM
just thought of something right when i hit post, your tranny probably won't be able to handle to the power coming out of the 03 engine.
Old 08-31-2007, 09:32 PM
found out its a 6.0 not a 7.3
no go now right?
Old 08-31-2007, 10:13 PM
yeah no go on the 6.0 not with out a tranny, transfercase, compooper, wiring harnes, bla bla bla... its doable but you gota have a wallet to back that swap up
Old 08-31-2007, 10:14 PM
grrrrrrrrrrrr
not what i wanted to hear...
will a new style 7.3 bolt up to my trucks trans and everything?
Old 09-01-2007, 07:30 AM
the 7.3 tranny will not bolt to a 6.0 without an adaptor plate of some kind. would be easier to have th 6.0 tranny
Old 09-01-2007, 02:40 PM
Why don't you try to find a direct injection 7.3 out of an OBS, it will be much easier to do the swap...
