Fluid Change - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-11-2011, 10:30 AM Thread Starter
Fluid Change
I bought a 7.3L F-250 about 6 months ago. I am slowly trying to change all the fluids out so I know when the last time it was done. There is only about 157K on the truck. I just changed the oil, oil filter, and air filter. Next week I am thinking about the fuel filter and transmission fluid. Any advice for those two projects? Any tricks? What kind of transmission fluid do you recommend?
tucker0104 is offline
post #2 of 3 Old 11-11-2011, 01:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
While your doing the tranny you should swap the pan for a 4r100 with drain plug. Good luck I'm sure some one will chime in for amounts and types.
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 11-12-2011, 10:10 AM
Mercon 5 or dec 3 but mercon 5 is better and buy a motorcades
Fuel filter
DonF350 is offline
