2wd hubs rotors superduty? - Ford Powerstroke Diesel Forum
Old 11-07-2011, 05:09 PM
I was wondering if the spindle and rotor size is the same between OBS and SD. I do not know anyone with a 2wd to take a look at it. Does anyone know for sure?
I would like to swap rearend and front hubs/rotors to change bolt pattern over.
Old 11-07-2011, 05:58 PM
Nope diffrent and sealed bearing not serviceable like older trucks
Old 11-07-2011, 08:57 PM
Electrical Ogre
The rear hubs/spindles are a different length as well, so you'd have to swap the rear axle.
Not sure on the front, but the 2WD still uses bearings. You'll probably have caliper/rotor fitment issues though. Could always swap in new i-beams/radius arms/spindles if you're dedicated to the idea.
Old 11-08-2011, 09:56 AM
I figured as much, I have not messed with any 2wd superduty trucks. Thanks for the info.
Old 11-22-2011, 11:52 AM
Yes, the front rotors should swap between the 2wd OBS to superduty and you will have to swap the caliper and caliper bracket. The 4wd's are the sealed bearings not the the 2wd.
