trans pan drain plug - Ford Powerstroke Diesel Forum
Old 11-05-2011, 02:19 PM
Has anyone ever put a drain plug on their trans pan? Gonna change fluid and filter tomorrow. Its usually a mess. I use a masons mix tub underneath to catch it all. A plug like the oil pan drain plug would be sweet. Less mess with plug let it drain then drop the pan to swap out filter. Anyone?
Old 11-05-2011, 02:31 PM
I'd guess that a 4R100 pan is not the same as a E4OD?
Old 11-05-2011, 02:35 PM
It is a e4od. Looks like theres a spot to drill out and put one.
Old 11-05-2011, 02:46 PM
No I'm asking is the pan and bolt spacing the same between 4R100s and E4ODs? If so, just get a 4R100 pan and use it.
Old 11-05-2011, 02:52 PM
Im not really sure. If they are the same.
Old 11-05-2011, 02:55 PM
Nothing is ever that easy though
Old 11-05-2011, 03:04 PM
Found a universal kit from advance auto for $7 bucks. Says you just have to drill 1/2" hole in pan to accebt the bolt set up. Seems plausible. I' ll check the inside of the pan again tomorrow..... its been 30k since I last saw it.
Old 11-05-2011, 05:10 PM
Interior Guru
Feedback Score: 3 reviews
Those things always leak.
Buy a pan for a 2000 F350 4x4 with an auto from the ford dealer, it doesnt cost a lot, and get the gasket since its reuseable.
It comes with a drain plug.
The E4OD and 4R100 share the same pan IIRC
Old 11-05-2011, 05:37 PM
Transmission or Injectors
Last time I had my pan off, I drilled a 1/4" hole and welded in a nut. Its not high flow, but its a way to get the oil out.
From what I understand, the pans for a 4R100 and E4OD are the same, but I havent actually tried to swap them.
Old 11-05-2011, 07:01 PM
Send a message via AIM to Maverick1701
yes they are the same...just find a new one w/a drain plug and you are good to go.
I drilled mine on my first OBS and put a plug in there (there are a few kits floating around). My kit has some seals, nuts and bolt or something like that.
