Aluminum Radiator replacement, 2 Row - Ford Powerstroke Diesel Forum
Old 11-04-2011, 06:02 AM
I'm replacing my radiator hopefully next wk.
I'll be getting a 2 row ALL aluminum radiator off line from these guys Radiator, Condenser items in RadiatorClassic store on eBay!
And it has a limited Lifetime Warranty.
My current plastic tank unit is cracked and leaking like a sieve.
Anyone used one of these radiators and have any pros/cons about em?
Old 11-21-2011, 02:42 PM
Alright
The job is done, and tested.
So here are my issues.
The new Aluminum rad has square tanks which make the rubber rad mounts to tight. I had to trim allot off of all 4 rubber mounts in order to get the radiator to fit.
The stock radiator is rounded on the tank ends and there fore much narrower than the aftermarket one I purchased.
In the second picture you can see the trimmed mount on the left as compared to the factory appearance of the mount on the right.
Overall I am very pleased with the new radiator and really like the way it looks in the truck. Much cleaner than the old one.
Aluminum Radiator replacement, 2 Row-110_0001.jpg   Aluminum Radiator replacement, 2 Row-110_0004.jpg   Aluminum Radiator replacement, 2 Row-110_0006.jpg
Old 11-21-2011, 05:12 PM
Looks good, thanks for sharing! Notice any differences in cooling efficiency?
Old 11-21-2011, 07:49 PM
No not yet, I've only had it in for a few hrs.
My truck isn't road worthy just yet, I've got serious ball joint and tie rod issues.
Also, my oem radiator has been leaking for about a yr so I can't remember what sort of efficiency I should compare the new radiator to.
I will make this assumption though:
It's got zero sediment build up in it, no dented fins, fresh coolant, and the tanks are just a tad bigger than stock. So..... yeah I bet it cools better than the stock one did. but it might not be noticeable with stock gauges.
Old 11-22-2011, 07:07 AM
Here is what the new one looks like installed, looks much nicer than a plastic tank
