First truck buying tips? Need help!!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-03-2011, 11:38 AM Thread Starter
Question First truck buying tips? Need help!!!
Im hopefully gonna be lookin at a 94 f350, and was wondering if anyone had any advice as to what i should look for, and stuff that i should avoid. Any help would be great. the truck has a 5 speed with 125k on it.
Mxktm125 is offline
post #2 of 7 Old 11-03-2011, 01:10 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
low miles... 5 speed.... dana 60. cant really go wrong dude. is the 94 a powerstroke (94.5+) or a turbo diesel. the pre 94.5 is an IDI with a turbo on it i belive. cant really get a ton of power. you are limited with what you can do. also the IDI's had problems with cylinder wall cavitation due to the cylinder sleeves were thin and the cooling to the back of the engine sucked. something to think about. if you not lookin for a huge power truck and dont plan on doin a lot of mods them if the price is right....?? worth takin a look at
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 7 Old 11-03-2011, 03:03 PM Thread Starter
its the 7.3 powerstroke engine
Mxktm125 is offline
post #4 of 7 Old 11-03-2011, 03:41 PM
elrojo63's Avatar
Check the turbo fins for wear and shaft play. Look around for rust. Check out the core support and the wheel wells especially. You might want to see what gearing it has depending on what you want to do with the truck
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #5 of 7 Old 11-03-2011, 07:14 PM
ol_Blue97's Avatar
sound like a winner then..... listen for engine missing after its warm during the entire spectrum ot the RPM range slowly to listen for injector problems. look at the rear bolt on the exhaust manafold on pass side to make sure it hasnt snapped off due to high EGTs form bad turbo or excessive towing. liseten to the the transmission shifting between gears for syncros clipping. other then that check you oil and coolant for lack of maintainace and see who was driving it mostly to make sure it wasnt beat.
but seriosly with that milage, 5 speed, and the d-60, you have the peices of every truck we all peice together to make our trucks
JW... std cab or crew?
FRANK THE TANK
post #6 of 7 Old 11-04-2011, 01:29 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check turbo for pitting and shaft play, blow by test (turn oil cap upside down, if it fly's off bad, if it vibrates off good) test drive, make sure 4x4 works good, check for leaks of any kind, and enjoy
Welcome to the org
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 7 Old 11-04-2011, 05:04 PM Thread Starter
it was a standard but the guy sold it before i had a chance to go look at it. thanks for all the advice though.
Mxktm125 is offline
Tags
4x4 , 7.3 , powerstroke
