stage 1 injector install - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-24-2011, 08:53 AM Thread Starter
White7.3stroker's Avatar
Send a message via AIM to White7.3stroker
hey just figured id post and ask im helping a buddy pull his injectors today to send to rosewood diesel and i was juat wondering if there was any tips or tricks to taking the injectors out and putting them back in i have done it on a 2000 7.3 but not on a obs but i figured they would be close to the same but figured yall guys would know if there was anything i needed to know about..Thanks
White7.3stroker is offline
post #2 of 4 Old 10-24-2011, 11:10 AM
GAS
GAS's Avatar
You may already know this, but any time I have injectors out, I pull the oil passage plugs on the heads to fill them up with oil. Make sure that the HPOP reservoir is full also, it will start faster and save wear on the stater.
Micha, Pleasant Grove, Utah
99 F350 Crew cab long bed, Tymar intake(The real deal)
Zoodad, 4 inch exhaust, Dipricol gauges, WW,
gutted turbo pedestal and ebpv deleted big exhaust outlet, ccv delete
GAS is offline
post #3 of 4 Old 10-24-2011, 11:33 AM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
Also make sure you have a way to evac all the fluids that fall in the cylinder.
2002 f250 BFT Edition
dereku is offline
post #4 of 4 Old 10-24-2011, 07:21 PM Thread Starter
okay what is the best way to evac the fluids out and where is that plug located on the head if u had a picture would help me spot it but i will check the reservoir and we will prolly change the oil while we are at it dont think that be a bad idea either but thanks guys for the help!!
