Front frame horns - Ford Powerstroke Diesel Forum
Old 10-23-2011, 07:37 PM
Front frame horns
Just wondering if the front frame horns of a 92F350 2wd would be the same as a 95 250 4wd?? I want to fab up a tow bar to go pick up a non running truck thats 4 hours away and im thinkin thats going to be the easiest way is to jst use a tow bar. Also will the wiring be similar from a 92 idi to a 95 psd? or would i have to put my whole wiring harness in that cab
Old 10-24-2011, 05:32 AM
should be exactly the same. idk if they had light duty and heavy duty in 93 but as long as its got a gross over 8500lbs you'll be all set
Old 10-24-2011, 02:34 PM
alrigh perfect then i can just mock up a tow bar off my frame then
