what ya think - Ford Powerstroke Diesel Forum
Old 10-23-2011, 12:06 AM
what ya think
so iam going to do the straight axel swap i just got few ?s 1st is there a better year i should get my front end out of 2nd my truck has crazy miles on it like 367xxx should i go ahead and grab the f350 front springs also ?
3rd will it lift my truck any over stock
also if i am correct i need all the strering also?
thanks alot guysliar:
Old 10-23-2011, 06:04 AM
yes all the steering. and get the springs. im looking in to doing the swap and have read the 250 spring will ride reall bad
Old 10-23-2011, 06:22 AM
You will need all the steering components ,tie rods,tie rod sleeves, track bar and track bar bracket.You can use the pittman arm and the hubs off of the 250 axle.I believe the 92 thru 97 d60 will be ball joint type and older ones will be kingpin
Old 10-24-2011, 11:45 PM
i can get my hands on a 1989 f350 straight axel. so it would be king pin what the pros and cons of the to diffent types
Old 10-25-2011, 09:57 AM
Welcome to the org, use the 350 springs, unless you can get your hands on something better, and i hear the king pin is stronger, but I don't know much bout axles other than the ttb sucks
Old 10-26-2011, 04:04 PM
Grab the 350 springs both front and rear.
Just do a check on all seals and bearing on the axle before installing it..
I went with a newer one for the All Wheel Disc Brakes.. Also easier to change front Discs, Ect. .
Just grab everything off the other truck.. all the steering, springs. bolts. ect.
mine came with a stock steering stab.. i put duals on it then just rolled it under and hooked it up..
If the axle had been disconnected from the driveshaft for a while make sure you clean out the holes good so the bolts go back in smoothly
Good Luck with your swap
