BTS Valve Body Install - Ford Powerstroke Diesel Forum
Old 10-14-2011, 07:46 AM
About to order the BTS valve body from Beans, is that all i will need? already have a new pan with a drain plug i need to install too.
Beans Diesel Performance - BTS valve Body (Powered by CubeCart)
Also is the valve body change simple? i am a mechanic but never really messed with autos at all.
Old 10-14-2011, 03:06 PM
I haven't done a valve body or shift kit in years but if you are just replacing the body itself I wouldn't think it's to complicated .Shift kits required some drilling and different springs and check balls,but too me a complete valve body is ready to bolt in after removing the other one .Make note of the upper gasket when replacing and let us all know what's up
Old 10-14-2011, 03:24 PM
Very easy.
Valve Body Install Write Up With Pics
Old 10-14-2011, 06:25 PM
Delivers Pizzas For Fun!
VERY easy..... just did mine and i love it. it is only the acumlitor part so youare only removing the front part of the valve body. i got a core from another trans to send it while mine was in reoute so i could get the core back faster
Old 10-27-2011, 05:39 PM
Just installed, cant feel that much of a difference? not like the video at least
Old 10-27-2011, 06:25 PM
maby the problem is the fact your pump is weak. big improvement when i did mine
Old 10-28-2011, 05:43 PM
transmission has less then 15k on it tho?
Old 10-30-2011, 03:33 PM
?????? idk. did you give him a list of your mods when you got it done so he could tune the VB properly,
Old 10-30-2011, 04:06 PM
yea they also called and ask tire size and gear ratio
