95 7.3 F350 Sending Unit - Ford Powerstroke Diesel Forum
Old 10-13-2011, 04:43 PM
The black plastic on the end of sending unit in my truck has broken to pieces inside the tank spent several hours picking it out and cleaning the tank out, my question is where can I find one identical to what I have cause I see none on Ebay or Napa online, is this a factory piece? Poor truck can't run right when you got chunk of plastic covering the pick up tube, and I don't care if I have to buy the whole unit I can't even find that.
Old 10-13-2011, 05:21 PM
It's been too long since I have looked inside a OBS tank but it sounds a lot alike a fuel pickup screen. Alternatively I also found a sump that could be retrofit to the tank which I kinda like the idea of... need a excuse to drop the tanks again.
From Google
Auto Performance Engineering - Walbro fuel pick-ups
Fuel tank sump mod - eliminates pick-up tube - Ford Truck Enthusiasts Forums
http://www.*************.com/alligat...mp-design.html
ADP Diesel Fuel Sump Anodized Black - NO TANK DROP REQUIRED
***=diesel bombers without the space
Must be a competitor as the site is filtering it.
Old 10-13-2011, 06:18 PM
Electrical Ogre
I'd just install a compression fitting on the end of the pickup tube and extend it with more tubing. In SD circles it's referred to as the "Hutch mod." You'll have to measure to figure out how long the old plastic pickup unit was.
Old 10-13-2011, 08:22 PM
thanks I will search that
