Ball Joint Replacement Help
So I'm getting ready to replace my ball joints and I'm calling around pricing them. I give them all the required info and they're all telling me that these standard joints wont work with a 4.10 axle for what ever dumb reason. Is this true or just them being idiots? If so, where do I go (Don't dare say stealership) to get the "right" joints. Also what is the difference in them for my axle?
XRF Chassis | Automotive and Heavy Duty Chassis Parts | Parts Overview These are much better then Moog or Monroe. I plan on replacing mine since I am tired of have to replace them every couple of years. I am on my third set with only 168,000 miles on my truck.
interasting....... i wil keep that in mind
They will work as long as you tell them the GVW of the truck is over 5,000#.
There is no difference in the Dana 50/60's other than the gear ratio's. The axles housings, axle shafts, hubs, brakes, lockouts, steering knuckles, etc are the same no matter which gear ratio you have |
Napa PRO chassis parts. Lifetime warranty.....end of story.
I have them in my truck. They look good, great quality, and no questions asked they will replace them if they wear out for whatever reason. You cant beat that! |
put the XRF's in it ... thats what the guys (loggers) in Alaska use ....
get them here : XRF 2-K80026 2-K8607T KIT,K80026K8607T - The Tire Club |
