TowCommand Trailer Brake Controller (TBC) Retrofit - Ford Powerstroke Diesel Forum
post #1 of 27 Old 10-09-2011, 08:28 AM Thread Starter
Transmission or Injectors
lwillson's Avatar
Soon.........
lwillson is offline
post #2 of 27 Old 10-09-2011, 12:46 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
here we go........ did you make some progress to retro fit the master cylinder pieces on?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 27 Old 10-09-2011, 07:17 PM Thread Starter
lwillson's Avatar
No, master cylinder won't fit. I've been playing with a 0-5v signals to spoof the pressure transducer. Looks like it uses the transducer instead of the brake light signal to engage the controller. It is a pretty cool controller, except that it won't engage without the ignition on.
lwillson is offline
post #4 of 27 Old 10-09-2011, 07:31 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Not to bust your balls but why? You can just buy a smart brake that will bolt right in and work
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 27 Old 10-09-2011, 07:35 PM Thread Starter
lwillson's Avatar
Doesn't matter how smart they are, they still don't work with pedal pressure.
AND......., because I can
lwillson is offline
post #6 of 27 Old 10-09-2011, 07:38 PM
Quoted: 4 Post(s)
That is how the smart brake work. Off brake pressure. A T goes inline off the master cyl and a pressure sensor reads brake pressure , converts it to volts and then sends it to the trailer
post #7 of 27 Old 10-09-2011, 07:52 PM Thread Starter
lwillson's Avatar
This was with my wreck, so it hasn't cost me anything so far. And its more fun this way.
lwillson is offline
post #8 of 27 Old 10-10-2011, 04:45 PM
ol_Blue97's Avatar
GOOOO team Larry... i with you, its just the principal that you can do it and you can say u did it
FRANK THE TANK
post #9 of 27 Old 10-10-2011, 08:40 PM Thread Starter
lwillson's Avatar
Originally Posted by ol_Blue97 View Post
GOOOO team Larry... I'm with you, its just the principal that you can do it and you can say u did it
Thats the reason behind everything, isnt it? It should fit in cubby hole under the steering column and integrate nicely.
lwillson is offline
post #10 of 27 Old 10-11-2011, 05:46 AM
bfever74's Avatar
I'm subscribed, I want to see how this turns out. Sounds like a fun project.
1996 F250 PSD 4x4
X-Cab XLT 4.10's
DIY 6637 - MBRP DP - 240k
2008 F250 PSD 2wd
X-cab XLT
Bone Stock 225k
bfever74 is offline
