Think My Headgasket is Going - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-07-2011, 11:49 PM Thread Starter
mitchellfried's Avatar
Today I took my radiator cap off and I had a black film on the cap. So I cleaned it off and went for a drive and came back and let it cool and there was black film on the cap again. I then left the cap off and ran the truck for awhile and I could see and oily film skittering back and forth in the coolant. Has anyone done a head gasket on their 7.3? Mine has 225,000 miles. Its pretty much stock except for a superchip, intake and a downpipe. Whats your guys's thoughts. Should I keep running it or fix it or sell it? Will I run into problems right away?
Thanks
1994 PSD Regular Cab Long Box
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
2006 Dodge 3500 6 Speed
846hp, 1456tq
mitchellfried is offline
post #2 of 7 Old 10-08-2011, 12:31 AM
JSchuricht's Avatar
Start with injector cups. The head gasket on the 7.3 usually stays put unlike the 6.0.
JSchuricht is offline
post #3 of 7 Old 10-08-2011, 12:52 AM
444 ci's Avatar
your oil cooler is bad my 7.3 did the same thing. your injector cups would let diesel not oil into your coolant.
444 ci is offline
post #4 of 7 Old 10-08-2011, 12:58 AM Thread Starter
How big of a job is it to swap the oil cooler?
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
846hp, 1456tq
post #5 of 7 Old 10-08-2011, 08:19 AM Thread Starter
Bump
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
846hp, 1456tq
post #6 of 7 Old 10-08-2011, 02:54 PM
Chop's Avatar
Most likely the o rings have gone bad,you don't have to replace it .Look underneath the left exhaust manifold and you will see the cooler with the oil filter mounted to one side and the block heater is also mounted in it too.5 bolts,wiggle it out .There many good write ups on this.Cooler repair kit around 60 bucks at Ford
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #7 of 7 Old 10-08-2011, 03:57 PM Thread Starter
Ok. Thanks a lot
5 Speed
AFE Cold Air Intake
Superchip
3'' DP
846hp, 1456tq
