Boost gauge reference location - Ford Powerstroke Diesel Forum
post #1 of 16 Old 10-07-2011, 05:28 PM Thread Starter
Hi all I was wondering where do most people reference the boost gauge from? I have mine teed off from the map but keep getting weird boost signals (gauges is jumpy). Thanks in advance.
Turbo_pace is offline
post #2 of 16 Old 10-07-2011, 05:51 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
i belive most guys are tapping a fitting directly into the spyder.... what brand gauges?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 16 Old 10-07-2011, 05:58 PM Thread Starter
It's an autometer carbon fiber 35 psi gauge, I think I'm just gonna drill and tap the compressor housing like I did on my mustang.
post #4 of 16 Old 10-07-2011, 06:01 PM
ol_Blue97's Avatar
i belive many people have had jumpy reading with autometers when they T them in... i say drill and tap away. not sure about in the compressor housing but i guess you cant get the reading any closer to the turbo than that
FRANK THE TANK
post #5 of 16 Old 10-07-2011, 06:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mine is tee'd in the map line and works fine, only time it's close to jumpy is when I'm hitting 20+ psi, but I have heard if you call autometer they will buffer it a bit for free to get that out I have the z series in my rig, gonna move it to the spider eventually when I intercool my rig
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 16 Old 10-07-2011, 09:40 PM
08spartan250's Avatar
thats where i have mine and i don't have any problems. its smooth up to over 35. maybe you have a loose fitting in it somewhere?
-Mike
2005 F-250 Lariat
Originally Posted by azkcr View Post
And you didn't know Cummins can manage 127mpg??? They also deliver babies, go to Mars, and cure AIDS. DUH
08spartan250 is offline
post #7 of 16 Old 10-07-2011, 09:48 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
Some people have this problem when they are "t'ed" into the MAP line. Moving it to the "y" pipe or the discharge of the compressor housing should solve it.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #8 of 16 Old 10-08-2011, 12:35 AM
JSchuricht's Avatar
Had that issue on my OBS. Filled the end of the T in the MAP line that connects to the gauge with epoxy and drilled a really small hole in it, think it was a #60 bit.
JSchuricht is offline
post #9 of 16 Old 10-08-2011, 02:30 PM
bfever74's Avatar
I'm Tee'd into the MAP line, and get smooth movement. But my truck tops out at 13 psi. I did notice during installation that it is pretty easy to kink the line when threading it from the gauge, through the instrument panel and out the firewall. Just something to think about. And I have the el cheapo Glowshift gauges that all the rich guys on here say to never use.
1996 F250 PSD 4x4
X-Cab XLT 4.10's
DIY 6637 - MBRP DP - 240k
2008 F250 PSD 2wd
X-cab XLT
Bone Stock 225k
bfever74 is offline
post #10 of 16 Old 10-08-2011, 03:06 PM Thread Starter
Well I drilled and tapped the y that comes of the turbo and go to the engine and that fixed my problem, and ya my truck hits about 15psi max. What is the flange on the turbo? Is it a t3 flange or a t4 flange? Thanks.
