turn signal problem - Ford Powerstroke Diesel Forum
Old 10-05-2011, 03:54 PM
turn signal problem
have 96 psd, and both of my turn signals(right and left) flash really fast. i have had OBS trucks before and the turn signals didn't flash as fast as this 96. could the flasher be bad
Old 10-05-2011, 03:57 PM
Burnt bulb? LED bulbs?
Old 10-05-2011, 04:09 PM
neither, bulbs are fine
Old 10-06-2011, 08:01 AM
Replace the flashers with electronic ones.
Old 10-07-2011, 12:24 PM
Interior Guru
Feedback Score: 3 reviews
Yup. Replace the electronic flasher relay in the fuse block under the dash. Its the round thing in the bottom corner. If you so have led bulbs. You need an led compatible flasher relay.
Old 10-08-2011, 07:31 AM
I've got the same problem in my 96! Just never got around to fixing it. Let me know where you get yours from.
Old 10-08-2011, 02:20 PM
Mine blinks normal for 3 flashes, then blinks fast for about 10 seconds, then repeats. Crazy. I figured the flasher is getting weak, but haven't got around to replacing it. It still shows up fine at night. If someone finds a solution, please post. in the meantime, I'll try to pick up a new heavy duty flasher
Old 10-08-2011, 08:45 PM
Mine just flashes really fast but if I have it on for too long, it'll just stay lit and stop flashing. Then i have the choice of not using it at all or having to make it flash by manually turning it on and off multiple times lol. Gets pretty annoying.
Old 10-09-2011, 09:20 AM
More then likely all flasher issue. Replace it and be done with it.
