Trans swap?
Will a trans from a '95 work in a '97, same chassis? My '95 is trashed($1k+ to fix the frame) but someone is selling a '97 that just needs a trans and electrical work, trying to get a feeling if its worth it. Thanks
If it's the same motor than yes, check to make sure they are both e4od, pretty sure it wouldn't be a 4r100, but crawl under to make sure, either way it will swap down to the e4od, just can't swap up to the later motor, good luck
Thanks, I just checked the codes after I posted that
Is there any other major differences between these years?
Trans will swap if they are both 7.3's. There are a few differences, your 95 may have the older style HPOP depending on when it was made and the 97 will have different injectors and PCM if it's a CA truck. Otherwise it's just whatever trim options that you may have to swap.
| Tags |
| 4x4, transmission |
