96 f250 7.3L power loss - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-28-2011, 05:52 PM Thread Starter
hi there new to forum...long time reader ,but new commer.. I have a 96 f250 extended cab 4x4 with 5 speed manual... 149K miles...runs great...love the truck.. I had 4:10 gears in diff and revoved them because of poor fuel milage..put in 3:55..get 20 MPG..reall happy...anyways hoping someone could help me out...I pull a 25' fith wheel that weight is roughly 10 000 pound...all kind of bottom end torque..could be in 4th gear doing 40 mph low rmp step on the accelerator and pics up and gone in no time...but here the kikker..on the highway at 60mph not bad 65mph no more power...when the accelerator is about 3/4 way to the floor I have no more power,with camper on the back or not towing anything...it seems when I first get going I have to press on accelerator down about 1/4 of the way just to get going..when I hit 1/2 way down all kinds of pick up and here turbo kick in,but 3/4 and to the floor I actually start loosing power ,but if I let up to 3/4 or so starts picking up again..all the power is the 1/2 way point..but tons of bbtm end torque...my first diesel and love it but need ti figure this out..put the truck on a scope right from international and nothing came up....so would anyone like to take a guess on this ..thanks
ford50 is offline
post #2 of 12 Old 09-28-2011, 06:09 PM
AWS96's Avatar
Have you changed the fuel filter? Air filter? Do you have a cat? Stock or chipped? Tire size? If you are running 285s or smaller your gears should not be a prob. Do you shift down at 65? These are a few things to look at to get started.
For those defending freedom, we wear this patch proudly to show our support for those serving in the military!
96F250 256K+
,transbuilt,EdgeEvo,strait pipe
07exploder stock!
67fairlane 500 not quite stock!
Originally Posted by westcoaststrokin
Ever had one of those days where you wish everyone at work would suck start a shotgun? Yeah that about describes mine.
AWS96 is offline
post #3 of 12 Old 09-28-2011, 06:13 PM
sldghamr's Avatar
several things to check:
1. do your maintenance first (oil/filter changes)
2. the throttle position switch could be bad
3. bad fuel pump
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #4 of 12 Old 09-28-2011, 06:21 PM Thread Starter
fuel filter new,air filter new,stock engine..tires are 245/85/16 10 ply..the reason I took out my 4:10 gears is because on hyway at 60mph in 5th reving 2400rmp...getting 15mpg..so could not downshift..now with 3:55 gears reaving 2200rmp at nearly 70 mph...everything seems good and pulls great but no power or should I say start loosing power when gas pedal is past 3/4 mark..just no top end...I mean I could fly at 80mph no problem as long as my gas pedal does not exceed 3/4 way to the floor..anything after that I don't really lose speed but don't gain either,but you kind of feel nothing happening as you depress pedal to the floor ...
ford50 is offline
post #5 of 12 Old 09-28-2011, 06:24 PM Thread Starter
no idea if I have a cat or not...under the truck roughly under passenger door door there is a piece on exaust pipe..don't know if it is a cat or a silencer... and back farther muffler ..I see that stock down pipe crimped will have to go later...
ford50 is offline
post #6 of 12 Old 09-28-2011, 06:48 PM
AWS96's Avatar
Your cat will look the same as one on a car. Did you look in the bottom of the bowl to see if it's clean when you changed the filter?
96F250 256K+
07exploder stock!
AWS96 is offline
post #7 of 12 Old 09-28-2011, 06:50 PM
jasons 7.3 powerstroke's Avatar
sounds like position "glitch" in the accelerator sensor, i would put on machine and watch that... thats the first thing i would check i've put on quite a few of those...
96 f250 4x4 zf5 trans. 6637 air filter mod.
jasons 7.3 powerstroke is offline
post #8 of 12 Old 09-28-2011, 07:00 PM Thread Starter
I know every now and then you press down on accelerator pedal and nothing happens...one day on the hyway pulled out to pass a car put the pedal down and nothing happened..only did it once..2 other times in town..so 3 times total in 6 moths..
ford50 is offline
post #9 of 12 Old 09-28-2011, 07:02 PM
AWS96's Avatar
If thats the case you could check for a TP code like a P1125.
96F250 256K+
07exploder stock!
AWS96 is offline
post #10 of 12 Old 09-28-2011, 07:04 PM
AWS96's Avatar
Sounds like jasons 7.3 powerstroke mite be right!
96F250 256K+
07exploder stock!
AWS96 is offline
