rim ?s - Ford Powerstroke Diesel Forum
Old 08-22-2007, 04:53 PM
rim ?s
Hello I was wondering if the alloy hubs with the ford emblem in the middle will fit old ford steel rims. They are just general ford truck rims from 1980-1997. Also what hubs would fit besides those nasty old hubcaps? Thanks
Old 08-23-2007, 07:06 PM
bump..................................
Old 08-26-2007, 05:58 AM
BIG TRUCK, SMALL DRIVER
I like the '80's stlye turbine looking hubcaps. Are you talking about using the hub covers from a SD?
Old 08-26-2007, 06:52 AM
no..... using the chrome center caps off of like a obs with those factory fcenord aluminum w rims. And Put those center caps on 80s style steel wheels. like the center caps off rims like these... http://www.theautochannel.com/media/..._ford_f250.jpg
Old 08-26-2007, 11:38 AM
Electrical Ogre
Probably won't work. The OBS center cap uses 4 teeth that fit in recesses in the rim to hold them on. If you got some at a wrecker, you could experement with some sort of getup to grab against the protruding hub to secure it.
