Is this a stock part? - Ford Powerstroke Diesel Forum
Old 08-18-2007, 09:30 AM
I am still having intermittant pedal problems with a CEL.
I noticed a black box under the dash that says throttle adjustment on it. It has 2 connectors and a potentiometer in the middle for adjustment.
Is this a stock ford part for a 97 powerstroke?
The truck was a city and lighting truck with a full hydraulic setup and plow, so I thought maybe it was added on.
Old 08-18-2007, 09:32 AM
duct tape & zip ties
That sounds like something for the stuff the city put on the truck for work.
Old 08-18-2007, 10:59 AM
Here is a pic of it.
Old 08-18-2007, 11:10 AM
It does not look stock at all to me.
Old 08-18-2007, 12:27 PM
DKR DKR is offline
<--Pro Cooler Racer
Doesn't look stock....with the "throttle adjustment" knob, wonder if it is some aftermarket idle control unit?
Any codes from the CEL?
Old 08-18-2007, 12:36 PM
it looks like idle speed controller. Does the truck have (or had) a pto? they use em to bumpo up the idle speed either for a PTO or long term idling running like an inverter or something.
Old 08-23-2007, 05:32 AM
It looks like there are two connectors plugged into it. If you unplug them will the two connectors plug into each other and bypass the box?
