I think I might need a new turbo - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-14-2007, 08:59 PM Thread Starter
The links are to pictures of what I found when I took off the hose and checked out my turbo. My truck has been kind of weak at higher RPMs (low-end torque is still really good) and I suspected the turbo might be to blame. I didn't have any black smoke at high power, though - which led me to think it might be something else for a while. Anyway, when I looked inside, I figured a new turbo was probably in order regardless of it being the root of the problem.
Turbo 1
Turbo 2
I figure the oil is due to worn out seals of some sort. Any idea what would cause the blades to be bent like that? I don't know how something large would have gotten down the intake.
Here's the turbo I ordered - seems to be from a good guy (100% positive with almost 2500 feedback).
eBay Motors: BANKS 94/97FORD POWERSTROKE 7.3 TURBO TURBOCHARGER 1.00 (item 120149569156 end time Aug-14-07 20:35:28 PDT)
Also, should I replace the connecting hoses between the engine and the y pipe? They look pretty old and crusty. Where would I get something like that?
Thanks!
Ryan
2002 F250 CC SB 4x4 Lariat - currently all stock except bedside toolboxes
1997 F250 CC SB 4x4 XLT
shuck is offline
post #2 of 8 Old 08-14-2007, 09:46 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 117 Post(s)
Oil residue in the turbo is common unless you have modded you crankcase vent system. Crankcase vapours vent into the cast pipe before the turbo, yeilding a coat of oil on everthing from turbo inlet to the head intake tubes as it is sucked into the engine.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #3 of 8 Old 08-14-2007, 10:38 PM Thread Starter
What about the puddle of oil in the bottom of the turbo? I started up the truck and let it run for a bit with the tube off (while ensuring clean, undisturbed air) and the puddle of oil was still at the bottom of the housing. I would have expected it to go away.
What about the bent blades?
shuck is offline
post #4 of 8 Old 09-12-2007, 11:14 AM Thread Starter
I have ended up isolating this to an exhaust leak (or perhaps a few). The bolt by the #7 cylinder was broken off of the exhaust manifold and it's leaking there. Who knows what shape the up pipes are in - but I'm going to try to work on those when I take the turbo out and replace it. Any ideas on replacements for those? I know there's an International replacement that doesn't require donuts, which is an attractive option to me. I hate repeating repairs.
Any thoughts?
shuck is offline
post #5 of 8 Old 09-12-2007, 11:53 AM
Power Strokeaholic
super_stroke's Avatar
like what was said above oil is normal. the blades are not. they shouldnt be bent. have you looked into geting just the compressor wheel? it's way cheaper than a whole turbo. i havent heard about the IH replacment but if its really out there look into it more. oh, that oil puddle wount go away. if you wipe it out with a VERY clean cloth. and run it for a while the oil wont be there. but when you bolt the intake tube back up the oil mist will start again and the puddle will be back.
Bill
2000 f-250 4x4 ex cab 7.3 psd. diablo programmer, TS 6 pos.
, 4" exhaust turbo back w/ 5" stacks, wicked wheel, HX cross over, zoodad mod, 6637 mod, boost pyro & trany on the a pilliar. 315/75/16 bfg mt's,.superwinch hub's, 6.0 trans cooler, banks trans command. sky jacker leveling kit
super_stroke is offline
post #6 of 8 Old 09-12-2007, 02:05 PM
lilredpowerstroke's Avatar
Yes International has a fix for the leaking donut gaskets. Black Widow Diesel This are ceramic coated and they also have uncoated ones which you would be able to get from International. I have the coated ones that I need to put in.
EDIT: I just realized I was in the OBS forum. I dont know if these will work on the OBS. Call up Kevin at Black Widow and see what he says.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #7 of 8 Old 09-12-2007, 06:20 PM Thread Starter
I found these up pipes for OBS trucks. Kind of expensive, but might be worth it. It's an extra $125 for ceramic coating. Is the ceramic coating worth the $$?
http://shop.blackwidowdiesel.com/pro...&productId=369
shuck is offline
post #8 of 8 Old 09-12-2007, 06:54 PM
so did you get that turbo? I was thinking about getting the same one from that guy if mine took a crap. I'm curious as to what it's like compared to the stock.
My turbo looks just like yours after almost 300k miles.
Raymond S. is offline
