Does anyone happen to know the part number for the fender mounted starter relay on a 1996?
My problems are not unlike Muddvol's in Bad starter or something else? . In case it's not the loose wire, I'll need to find a replacement relay if it's bad. Also, does anyone know how to test the starter relay? I want to check it out before pulling the starter itself to be tested. Thanks! |
to test it just use a test light and see f you have power to the small red wire coming into the solenoid from the igntion switch if it as power but the starter isnt engaging the solenoid is bad , it should transfer powr to the other side of the solenoid on the big terminal , if its not , then replace it
I stuck a multimeter on the relay and got 12.2 volts. I then jumped the terminals and heard the solenoid engaging with a solid click. Looks like I'll be installing a new starter tomorrow afternoon.
If this thread s/b in the "94-98 7.3L Problem Forum", please move it. Sorry I didn't post there to begin with. |
