4x4 and chip question - Ford Powerstroke Diesel Forum
Old 06-16-2011, 05:35 PM
Send a message via MSN to 95_Powerstroke
So I have a 1995 F-250 4x4 auto and when I try and engage the transfer case it is extra extra hard and requires lots of force and frustration to get it to change between 2 Hi, 4 Hi, and 4 Lo. It also seems like they are not in the right places if that makes any sense; it appears like it is in 2 hi but the 4x4 light on the dash is still on, if I keep pushing and wiggling it will eventually click forward and the 4x4 light will go off. And after all this, the 4x4 does still work from what I can tell. Should I just service it or is something wrong with the transfer case? I was planning on servicing it this week end anyway. Any help/info/advice would be greatly appreciated.
Second question concerns a chip. My brother bought a 2001 F250 a few months back and it came with a tuner. I'm not sure what type at this point but I will find out. It has 3 settings, economy, tow, and extreme (I think) and he bought a new DP tuner so I was wondering if this chip would work for mine or if I would need to have it re tuned. If you guys think it'll work, I'll take it off his hands and use it until I can afford my DP tuner, I just don't want to hurt my truck.
Sorry for the long questions, thanks again for any help.
Old 06-16-2011, 06:27 PM
That's strange with what's going on with your transfer case. I can't help you there. Your other question, if it's actually a tuner, it will plug into the OBSII port. Your truck being a 95 it won't work, That is a 96 and newer port. Even if it's free, you'd be better off buying a chip since you have an auto.
Old 06-16-2011, 08:30 PM
Both the DP Tuner and the chip from my brother are actual chips that go into the PCM. I realized after i posted this though that I forgot he has a 6 speed so it will not work anyway. Oh well, thanks anyway. Still would like to figure out this transfer case issue. I do not want to waste the time or money servicing it if it is toast haha.
Old 06-17-2011, 08:21 AM
I don't want to state the obvious, but I had a very similiar problem with my 97 F350. I soaked all the linkages underneath in Krol Oil (penetrant/lube), I'm sure any would work, and now I can shift it with no issues at all.
Old 06-17-2011, 09:12 AM
That chip won't work in your 95,sorry.
Old 06-17-2011, 11:09 AM
Thanks, I'll give that a try and see if it helps.
@bucwheat thanks for the response. I'll just wait and get my DP instead
Old 06-17-2011, 01:00 PM
Electrical Ogre
Agree on the shift lever. Lubricate it and check it over to make sure nothing is bent or binding.
Old 06-17-2011, 07:13 PM
agreed. May need to chang the oil also. I'm sure it hasnt been shifted much.
