What Keyless Entry is This? - Ford Powerstroke Diesel Forum
Old 06-16-2011, 02:16 PM
Howdy Yall,
I am completely sick of the keyless entry on my truck. It looks like a factory or dealer option but I can't find any information on it. It only works about half the time, the other half I have to open the door manually and press the hidden button and all that to disable it. I would just stop setting it but it disables the ignition after 30-60 seconds. Does anyone have any idea what this system is and how I go about removing or disabling it? I would like to have it disabled or removed completely so I can go with a full-fledged alarm system. Thanks!
What Keyless Entry is This?-photo-3.jpg   What Keyless Entry is This?-photo-2.jpg   What Keyless Entry is This?-photo-1.jpg
Old 06-16-2011, 03:29 PM
Well it's certainly not factory installed RKE, might be dealer installed but I've never seen anything like it.
Old 06-16-2011, 06:20 PM
aussie=effie
Question keyless
have you tried changing the battery in the keyless pack ??
Old 06-16-2011, 07:07 PM
Feedback Score: 3 reviews
That is aftermarket and i've never seen that type of remote before. Whats the numbers on the back?
Old 06-17-2011, 09:40 AM
Electrical Ogre
That is a dealer installed system. Made by Code Alarm for Ford. I have one sitting here in a box after it didn't do what I wanted on the OBS.
Old 06-18-2011, 11:09 AM
Hey thanks Bill! Now that you mention it, Code Alarm rings a bell. Any idea how to fix, remove, or at least disable it?
Old 06-18-2011, 05:20 PM
Electrical Ogre
I'd say follow the wiring and see where the module (brain) is, then just cut and cap off the wiring.
Here is the dealer install manual:
http://www.ford-trucks.com/forums/at...7&d=1267121031
Old 07-08-2011, 08:03 PM
Thanks Bill! That's exactly what it is. I haven't dived too deep into the install manual but I found the box called "Ford Security Controller" or something like that zip-tied to some wiring near the kick panel. I unplugged all 4 harnesses and jumped 3 wires to re-enable my power locks and disable the starter lockout. As far as I know I'm back to stock.
That's just temporary however. I'm going to get a nice new alarm system (maybe remote start) installed. Will leaving that old one in mess them up or should I do my best to remove it? Thanks!
Old 07-08-2011, 08:13 PM
Electrical Ogre
It won't hurt it if it remained there, taped off. Personally, I'd remove it, or have the new system's installer clear it out for you. Nothing worse than a rat nest under the dash.
Old 07-08-2011, 08:16 PM
ΜΟΛΩΝ ΛΑΒΕ
Mine came with a remote start/alarm. I'm about ready to rip it out and just go to the factory FOB thingy....
