Down Pipe and Wheels - Ford Powerstroke Diesel Forum
Old 06-16-2011, 08:15 AM
Im new here and to powerstrokes but when I was looking under my truck I saw this crazy flat downpipe and thought thats gotta go. So, my question is will a 4" fit without major pounding? Or should I go with a 3" or 3 and a half"?
Next question concerning wheels. Can I directly fit newer ford wheels to my 97?
Well what do you think?
Old 06-16-2011, 08:22 AM
4" down pipe won't fit without extensive firewall modification. 3" down pipe is what most run.
Super Duty wheels will not fit. Wheels from a Dodge or Chevy 8 lug will.
Old 06-16-2011, 08:26 AM
Thats what I though about the downpipe. As for the wheels I can run say 3rd gen 8 lug dodge wheels?
Old 06-16-2011, 09:06 AM
Yeah any Dodge 8 lug wheel will fit. The only thing that won't is a 99+ SD wheel. Why Ford went to a metric bolt pattern I'll never understand.
Old 06-16-2011, 11:00 AM
Dodge steel wheels won't fit. I found out the hard way.
Old 06-16-2011, 03:27 PM
Must have been from a 2wd with the small hub opening?
Old 06-16-2011, 03:34 PM
No, they fit on the hub but hit the calipers. I could've possibly fixed em by grinding down the calipers or inside of the rims but i didn't wanna risk messing anything up so i just used the stock Ford steels.
Old 06-17-2011, 06:00 AM
When you say steel wheels do you mean the ones that come off a 1999 slt 16's
Old 06-17-2011, 07:26 AM
No, it wasn't them.
I don't know what they came off of. I was only told that they were Dodge 8 lug rims, and they looked like the OBS and older Ford steel rims.
Old 06-17-2011, 01:59 PM
Feedback Score: 5 reviews
You don't need larger than a 3" DP unless your making over 500HP..
Can you run SD wheels on a OBS yes..we can get you everything needed to swap SD 99-10 axles under your truck..
